Furnace & Ductwork replacement
Old 12-03-12, 06:47 AM
T
I currently have an inoperative forced-air oil furnace - cracked heat chamber and insulated ductwork is coated with oily soot.
I want to replace this furnace with a gas-fired furnace and, likely, the ductwork that was fouled with the oil soot, and I mean REALLY fouled.
My questions are:
* Can the existing oil furnace be dismantled and removed to be replaced with a gas furnace? Of course, the tank would be drained and disconnected.
* Is there a venting system for a gas furnace that doesn't require a flue?
* The ductwork is so fouled with soot that it must be replaced. The existing ductwork is insulated and in the basement. Would it matter to replace the ductwork with non-insulated duct? (really $$$! to replace)
Thanks!
Old 12-03-12, 03:12 PM
user 10's Avatar
Received 57 Upvotes on 50 Posts
If the basement is heated, metal duct is best; the way the duct system is designed will make or break your system.
Proper sizing is also very important.
Yes.
Yes. High efficiency furnaces vent through the wall using pvc pipe. If you have a masonry chimney with a water heater venting through it, you'll have to get a liner installed once the furnace is removed. (or replace the water heater with a power vent or direct vent model.
See above.
Read more: http://www.doityourself.com/forum/ne...#ixzz2E27nM9B6
Old 12-04-12, 06:21 AM
T
Thanks for the resonse, Muggle.
The water heater is electric, and I'll probably maintain that, for the present.
The basement is not heated and is unfinished, though I would probably like to install a register (or, two) to heat this space up to help keep it dry.
I wonder what kind of scrap metal would be useful from the existing furnace - that's going to be a joy to dismantle! LOL
Again, thanks for the reply!
Old 12-04-12, 10:00 AM
user 10's Avatar
If the basement is similar to an older crawlspace -> ventilated, unheated, with insulation in between the floor joists, adding registers and using uninsulated ductwork will dramatically increase your energy consumption.
The best option is to convert the basement into a conditioned space - seal it off, insulate above grade (not below unless your foundation has been water/damp proofed), and get a barrier put down on the floor if it's dirt. A dirt floor is one of the greatest sources of moisture.
Google "crawlspace encapsulation" if you have a dirt floor.
