Recommendations on a new gas furnace
Old 12-05-12, 10:08 AM
O
I am planning on replacing our gas furnace, a Holly rated at 80,000 BTU, which appears to be an original to the house (1958). It still works, but obviously we are wasting a lot of money running it.
Our house is a small single level, raised foundation, 3 bedroom, 1200 sq. ft. house with moderate insulation and new double-paned windows located in Southern California. I am looking for recommendations for a forced air furnace that would be right for the size of the house, and one that is very efficient.
Any ideas?
Thanks!
OldFrenchy
Old 12-06-12, 04:23 AM
hvactechfw's Avatar
Received 2 Votes on 2 Posts
call local contractors.
There is no BEST brand. It's all about the installation. If a good furnace is not installed properly then it will not function properly or last as long as it should. Part of a good installation is proper sizing. Part of a good installation is checking for proper duct work.
Old 12-08-12, 05:50 AM
B
Before you purchase a furnace from someone, call them on Friday night at 7 PM and see what kind of response you get from them. Service after the sale counts too.
Old 12-08-12, 02:20 PM
Houston204's Avatar
Received 17 Votes on 14 Posts
Carrier, Trane, and Lennox are some good choices.
The quality of the installation is more important than brand.
As long as it isn't a furnace with the Honeywell Smart valve is should be fine.
Old 12-08-12, 02:23 PM
lawrosa's Avatar
Super Moderator
Received 60 Votes on 52 Posts
LOL... I dont think they made the smart valve in 10 + years....
Goodman is reasonable...Its all in the install thought as the others have mentioned.
Old 12-08-12, 02:56 PM
Houston204's Avatar
That's good news since I'm not sure what 1/2 wave rectified AC is measured with.
Old 12-08-12, 06:34 PM
Grady's Avatar
Received 25 Votes on 23 Posts
Before replacing the furnace, improve the house envelope. Improving the windows, doors, & especially insulation will pay you back many times over & likely allow for a smaller furnace.
After the envelope improvements, do, or have done, a Manual J heat loss calculation & size the furnace accordingly.
Old 12-09-12, 09:35 AM
B
Most replacement jobs I go on I wind up bidding higher to try to correct the inadequate ducting. I would get a lot more jobs and make a lot more money if I just threw them in there and walked away....that seems to be the trend. My brother in Seattle just went through this same type of deal, what a mess when it was done
The new furnace is not very efficient if the air doesn't flow properly, and that's the true fact of the matter.
Old 12-11-12, 04:17 PM
R
Try using an oscilloscope
Old 12-11-12, 06:51 PM
F
Received 36 Votes on 28 Posts
Use an oscilloscope for what? How does this relate to furnace brands or installations?
Old 12-18-12, 12:16 AM
user 10's Avatar
Received 44 Votes on 38 Posts
Where is the furnace/ductwork located?
What does fair insulation mean?
The proper way to size a furnace is to do a load calculation.
Changes are that your current unit is too large.
