Oil heater not turning on...
Old 12-07-12, 02:18 PM
R
Hi...Have oil heat...The circulator is running, but no hot water is going through the pipes and the heater will not kick on. Again the circulator is running. Any idea what the issue would be?
Old 12-08-12, 05:37 PM
Grady's Avatar
Received 41 Upvotes on 39 Posts
There are many possible causes. Plenty of oil in the tank? When was the last service? Have you tried to push the reset button on the burner or aquastat? If so, what happened? DO NOT push it more than once.
