Magic Chef Forced Air furnace blower not working, loose wire
Old 12-10-12, 04:53 AM
F
I have a Magic Chef forced air furnace. I was changing the filter yesterday and vacuuming the dust out and now the blower does not work. Nothing, no clicks, no hums. I found a loose wire and am hoping that is the problem, but I have no idea where it connects. I hope someone can help me. Thank you.
[ATTACH=CONFIG]6500[/ATTACH]
Old 12-10-12, 05:45 AM
Houston204's Avatar
Turn off power to the furnace.
That blower will have a door switch.
Is that white wire bundled with the red wire connected to the Y terminal?
Looks like you are using blue from the stat for 24VAC common.
I don't see the air conditioner white wire on the C terminal in your picture.
A few more pics might help.
It would probably be a good idea to have this 20 plus year old furnace checked out by a pro.
Old 12-10-12, 10:59 AM
F
More Pictures
I agree it does need to be serviced, just haven't had a chance yet.
[ATTACH=CONFIG]6505[/ATTACH][ATTACH=CONFIG]6502[/ATTACH][ATTACH=CONFIG]6503[/ATTACH]
Door Switch
[ATTACH=CONFIG]6504[/ATTACH]
Old 12-10-12, 01:37 PM
Houston204's Avatar
Yep its common.
Wrap the loose white wire and the poorly connected blue wire around the lower left terminal currently in use by the blue wire.
This is not the reason this Furnace isn't running.
Old 12-10-12, 05:44 PM
F
Thanks for your help. I found a piece of copper wire under the black wire with the red tab, is that where the loose wire and the blue wire belong? Also, if this is not the reason why the blower is not getting power, is there anything else I could try? We have someone coming out tomorrow, but its going to be another cold night. thanks again.
Old 12-10-12, 09:21 PM
Houston204's Avatar
Yes, the black wire with a red connector is attached to common.
That white wire is for the AC unit.
The loose Blue common wire from the thermostat or that door switch with the orange wires would prevent the fan from running.
