Hanging Garage Propane Furnace hook up?
Old 12-10-12, 02:49 PM
Hello Ladies and Gentlemen,
This is my first post on this forum. I have recently purchased a Old NG furnace that was converted to propane. I would like to install this hanging propane furnace in my garage. I have called a few plumbers/gas fitters and they want my first born to do the job!!!! I am experienced in plumbing and a bit in gas fitting. My question is do I need to use hard pipe to hook up my propane? Would I be able to hook it up with a hose similar to this: Base Camp | Propane Hose/Regulator Assembly for Angle Iron Burners - 12 Feet | Home Depot Canada
This hose has a regulator on it already and my furnace will be mounted close to a outside wall so I can have the propane tank on the outside of my garage. Any help and suggestions would be much appreciated.
Old 12-10-12, 06:48 PM
Received 25 Votes on 19 Posts
Hose is for temporary or portable usage only. You may be able to use copper tubing with flared connections if your local code allows.
