Permanent Filter Installation
Old 12-13-12, 07:19 PM
Could anyone tell me which way a Permanent Filter should be installed? I have a green one, one side looks like a grid, the other side looks like a scrub pad. The instruction manual for the furnace gave no indication as to direction. There are no arrows on the filter & no frame.
Old 12-13-12, 09:43 PM
Received 2 Votes on 2 Posts
The padded side faces the cold air return and the grid side is closest to the furnace blower. Keeps the green filter material from being sucked into the blower.
Old 12-14-12, 02:55 PM
Thank You, that helps a lot!
Old 12-14-12, 06:23 PM
Grady's Avatar
Those filters are far from permanent. After 3 or 4 washings (maybe less), they get so flimsy they won't stay in place. I suggest saving yourself the headache of pulling filter out of the blower wheel by throwing that filter away & getting an ordinary disposable filter of the correct size.
If you really must use that type of filter, go to the hardware store & get some 3/16" rods to stiffen the filter.
Old 12-15-12, 05:38 PM
Jay11J's Avatar
Why are you going with these filters?
From my past trying these out, It was not worth it.
-The dirt becomes embeded into the fiber, and they don't come out.
-They are either very restricted on the air flow, or they don't filter out much.
Use the mid-lower ranger pleated filters.. if you must have a better filter, then upgrade to teh 4" media filter that you change out once/twice a year.
Old 12-16-12, 07:18 AM
Grady's Avatar
Well said Jay. My thoughts exactly. The only reason to use these things, even on a temporary basis, is some equipment's filter rack takes an odd size filter.
Old 12-16-12, 10:12 AM
chandler's Avatar
This may help the OP. I just had my system checked professionally. I have a Carrier inline electronic filter with prefilters in place. He suggested removing them and replacing with the 4" filter media, which should only need changing twice a year.......I did look at him out the corner of my eye, but acquiesced for $49. We'll see. Would like further input if you have it.
Old 12-16-12, 10:51 AM
Grady's Avatar
Good move Larry. Electronics are great, when they work which is rarely. If the ductwork is tight, the pleated 4" will do a very good job. You likely won't have to change it more than once a year, if that often.
Old 12-16-12, 10:55 AM
chandler's Avatar
More worms in the bucket.....we have dogs and cats. Does that reduce the anticipated life of the filter dramatically? I think one at each season change, or twice a year would not break the bank.
Old 12-16-12, 10:58 AM
Grady's Avatar
In a little time, you, better than anyone else, will know how often they need changing.
Old 12-16-12, 01:27 PM
Jay11J's Avatar
We have pets, and I change it twice a year, and I run the fan 24/7 in the winter.
