york diamond 80 not working
Old 12-16-12, 12:35 AM
G
so i started playing with my heater today. a few weeks ago i turned it on and it came on just fine. it cycled off and after about an hour tried to restart. the induction motor kicks on, i hear it ignite but the blower motor never starts and it shuts off. if i turn off the t-stat and wait a few hours and restart the system it starts and runs fine. but it will not allow the house to get past 72 degrees. im starting to think its detecting an overheat or something and not allowing it to turn on. i have replaced the filter in my hall way even though it was fine and no change. i downloaded the owners manual online and i think it shows that there are filters in the furnace itself. if they are dirty would it cause this condition? or is it something else.
Old 12-16-12, 12:29 PM
Received 4,055 Upvotes on 3,638 Posts
Check your airflow at the registers......is there a good flow of air ?
Some systems have the return filter at the hall mounted common return.
Most have a filter between the return air duct and the furnace. If you shot us a picture we could tell you if you have one there.
Old 12-16-12, 08:35 PM
G
i will post a pic tomorrow. thanks for the help. im not sure if i have good airflow or not. how would i tell?
Old 12-16-12, 08:44 PM
Do you have any airflow that you can feel ?
Old 12-17-12, 07:56 PM
G
yes i have airflow at all the vents. but my house is so damn big i dont know whats a good amount of air and what is not.
Old 12-17-12, 08:00 PM
What is the make and model of your heating plant.
