Carrier performance 80 two stage furnace continue on .
Old 12-16-12, 02:02 AM
HI EVERYONE , A CARRIER PERFORMANCE 80 FURNACE (PRODUCT 58CTA070_ _ _ 12112) RUNNING CONTINUE , REALLY OVER HEATING HOUSE & HAVE TO OPEN WINDOWS. OR IT SHUTS DOWN COMPLETELY AFTER OVERHEATING . SO FAR I TRIED INLET AIR SUPPLY ,CHANGED FILTER ,CHANGED THERMOSTAT,CHECKED THERMOSTAT WIRING ,CHANGED LIMIT SWITCH & CIRCUIT/ CONTROL BOARD , STILL PROBLEM . BUT IT RESPOND TO THERMOSTAT ON /OFF ACCORDINGLY .ANY SUGGESTIONS PLEASE ! TO RUN IT AGAIN HAVE TO RESET FROM POWER SWITCH .
Old 12-16-12, 12:24 PM
Received 215 Votes on 204 Posts
How could it be responding to thermostat if it stays on
You've got all kinds of terms listed but you don't seem to have any idea what is going on.
Is the burner staying lit and blower fan staying on all the time ?
Old 12-16-12, 03:37 PM
user 10's Avatar
Received 20 Votes on 15 Posts
Turn off caps lock.
Disconnect the thermostat wire connected to r at the circuit board.
If the furnace continuous to operate, the board is bad; if not, there's a short in the low voltage wiring or the t-stat is bad.
Old 12-16-12, 08:37 PM
Yes ,Furnace keeps running ,Burners ,Blower ,Inducer Fan. If We Manually On/ Off t Stat . Furnace Turns On /Off Accordingly . But Say I Set t stat On 22. & temp. Is reached to 30. furnace still running on.I Changed T stat . Its basic 2 wire honeywell t stat. Still same issue. Is Its Possible That New Control Board Is Faulty. I baught new from carrier dealer. If that is the case ,Will they replace it .(As its Electronic Part). ?
