Carrier Circuit Board Electronics Identification
Old 12-20-12, 10:10 AM
I
Hello All,
I have been troubleshooting my Carrier 58se "fan always on" problem thanks to this forum. It looks like I will need to replace the circuit board (302075-302), but I am really curious as to what this component is that I have circled red. Is it a diode? If it is, it is shorted. Can anyone identify it?
[ATTACH=CONFIG]6843[/ATTACH]
Old 12-20-12, 11:05 AM
P
Received 2,309 Upvotes on 2,054 Posts
It's a resistor. The colored bands tell you the value. It's basically just a larger version of the little ones above it.
Old 12-20-12, 12:03 PM
I
Ahhh, got it. I was hoping that it was a failed diode and an easy fix. The only thing left that I don't know how to test is the triac/timer, but looks like I still need to order the new board.
Thanks for your response.
Old 12-20-12, 12:33 PM
P
You can test a triac using a multimeter. If I recall correctly the triac needs to be removed from the circuit for testing.
The good thing about most triacs is they are pretty generic. If your's is a three wire/pin that really narrows things down.
Old 12-20-12, 12:36 PM
SeattlePioneer's Avatar
Received 1 Upvote on 1 Post
Replacing parts on the circuit boards of heating equipment is not recommended.
If the board isn't working properly, replace the circuit board. That's a VERY old board, and by replacing it you replace a lot of other old parts as well.
Old 12-20-12, 04:52 PM
I
Yes, I am going to replace the board. I wouldn't risk creating a fire hazard over the purchase of a ~$60 part. But I would try repairing it just for fun if it came down to a $3 diode. I enjoy the process.
Thanks.
Old 12-20-12, 05:47 PM
user 10's Avatar
Received 57 Upvotes on 50 Posts
Have you ruled out the obvious things - short in t-stat wires (between r and g), high limit not stuck open, etc?
