S8610u ignition control
Old 12-23-12, 05:33 AM
I have installed 2 Honeywell s8610u ignition control on a Lennox g16-q4/5-125-1 gas furnace. Both controls are giving me a "9" flash code, which is not listed in the book. I have checked the wiring and replaced the flame sensor and wire. Also have cleaned pilot and ran a dedicated ground from pilot to control ground. Very strange. Never had this before. Any clues?
Old 12-23-12, 01:57 PM
Grady's Avatar
Received 37 Votes on 35 Posts
Check that flash code again. Count the number of blinks, 2 second pause, count blinks again. These blinks should be at a rate of aprox 2 blinks/second.
Old 12-23-12, 06:35 PM
I get 1 blink, then about 2 second delay, then 9 blinks with 1/2 second between blinks. I have never had this before. I have installed 50 of these ignition controls. Very puzzled. Sometimes I feel like I am loosing it. I will contact Honeywell tomorrow. Just thought I would give this forum a try. Thanks though.
Old 12-24-12, 10:34 AM
Grady's Avatar
Mike,
I've never seen that either. I'm sure you've already done this but, double check your polarity & ground. Those are a couple of things which can cause screwy error codes.
Merry Christmas
Old 12-25-12, 01:53 PM
Tks again Grady. I will post after contacting Honeywell tomorrow in case this might be helpful in future.
Old 12-25-12, 01:58 PM
Grady's Avatar
Please do. I've talked to several other guys in the trade & none have ever seen what would seem to be a "19" code.
