Thermostat Hookup
Old 12-23-12, 03:58 PM
Thermostat Hookup
Hi,
My thermostat has
B O G Y W R RC
My Furnace has
C G R W Y TWIN
Right now They are hooked up with (first letter Thermostat, last one is furnace)
B -> G
G -> C
Y -> Y
W-> W
R-> R
All other not hooked. (Note I also do not have AC)
I'll start by saying EVERYTHING works except the fan is ALWAYS on, even when I put fan on AUTO in thermostat.
So I thought it must be because G is not hooked to G (For fan control).
So I switch G->G and B->C (reading that B was common on older stuff).
BAM my 5A fuse breaks.
I think okay, maybe B isn't common so I just hook G-> G and disconnect B AND C.
Okay now my furnace ignites, but the FAN will not turn on. So my question is what am I doing wrong? And why the heck does this actually work in its current configuration? Thanks
Old 12-23-12, 04:26 PM
Received 3,614 Upvotes on 3,240 Posts
G must go to G.
G is fan control for A/C and FAN ON mode.
Old 12-24-12, 02:05 AM
I tried hooking G-> G and hooking my Thermostat B to Furnace C
I had a blowup of 5A fuse.
My next step was to not hookup Thermostat b nor Furnace C, and just leave G-> G
THis time my furnace ignites, but I feel NO AIR coming from my vents.
SO i then hook Thermostat G -> Furnace C and Thermostat B to Furnace G,
Now i get hot air. What am I doing wrong? WHy and how is this working in the current configuration. Can someone explain to me? Thanks!
I really want my fan to turn on/off as needed instead of constantly being on blowing air even when thermostat is set to AUTO and not giving heat.
Old 12-24-12, 09:20 AM
hvactechfw's Avatar
Received 4 Upvotes on 4 Posts
C does not get wired to the thermostat.
Old 12-24-12, 12:37 PM
That's actually really good to know. So if C doesn't get wired to the thermostat, I wire G->G, it seems like there is no air coming from the vents. Am I missing something?
Old 12-24-12, 01:17 PM
hvactechfw's Avatar
The fan on a GAS furnace should turn on 45 - 90 sec. after the burner starts. An electric furnace needs to be controlled by the thermostat. SO on an E furnace the thermostat needs to be setup to control an electric furnace.
Does the fan turn on if you switch the fan to on at the thermostat?
