Bryant heater won't start.
Old 12-28-12, 06:54 AM
D
Bryant hvac model 582ANW030060NAAD FAULT CODE 8 . Only works if I reboot the power. I'm not sure if I read the code right and haven't found the code key in the panel I removed. Any help would be nice !
Old 12-28-12, 02:15 PM
SeattlePioneer's Avatar
Received 1 Upvote on 1 Post
Take the cover off the burner compartment of the furnace.
Describe the sequence of events which occurs when you turn up the thermostat in detail.
Usually the index of diagnostic code is found on the inside of the blower compartment door.
Usually Bryant diagnostic codes have two parts, so you want to check that again and look for the explanation for the code given on the index.
