fan blower blows no heat
I live in Ontario temp -5 -12.
I have a frigidaire 80,90 upflow gas furnace. roughly 7yr. standard digital honeywell thermostat.
2 storey house 1700sq ft
The warning light I am getting is continous flashing red which is (false flame or gas valve relay shorted)
something that i have noticed is that it has gone off twice this week, once three days ago at night during a fairly heavy snow fall, and last night again but not so heavy snow fall. Ive reset it at the vent relay switch and it worked, but what is causing the problem?
Take the cover off the burner compartment of the furnace.
Obtain the model number off the rating plate in the burner compartment and report it here.
Report the sequence of events that occurs when you turn up the thermostat ---in order and in detail.
Also, describe what you call a vent relay switch and where it is located. Is this a resettable temperature limit switch that resets when you push it in?
Model # L1RA-090C-16B
The Switch underneath the Burner assembly where the blue wires run to. It tripped again last night and reseting it is not working.
when I shut it off and turn it back on and when i crank the heat the same thing happens, the blower fan just runs and the red light flashes continously on the control board nothing else happens.
