Closing Vents in Unused Rooms
Hi all!
I have a finished room in our basement that we don't use for anything but storage really (or as the occasional guest room), and we keep the door closed to keep the cats out. It gets quite warm in there, which seems like such a waste of heat.
I know, however, that I've read that it isn't a good idea to close vents in rooms that are unused. Everyone seems to think I'm crazy when I tell them this.
Can I close those vents, or is there a reason for me to keep the vents in that room open? If there is a reason, what is it?
Thanks!
-JP
Thanks!
-JP
How many vents in the room? If more than one, I would consider closing some of them (but not all). It certainly sounds like you have too much heat being dumped in there.
If theres two you should be ok with closing one if not the second one half way. But becareful and make sure you dont close too many youl create more heat in ur firebox and the unit wont run cause of the overtemp sensors in the box. If your house is plenty big enough and you have enough vents in the rest of your house you should be ok.
Don't close vents - just slightly close the dampers in rooms which are too warm.
Closing vents reduces airflow through your furnace/ac; insufficient airflow reduces capacity, efficiency, and may cause damage. Most duct systems are probably undersized with everything open.
