Trane XE-78 no heat
Old 01-13-13, 05:07 PM
D
Exclamation Trane XE-78 no heat
The system only blows cold air. I watched the startup sequence and the ignition glows red for a few seconds then fades. It does this a couple of times and then the blower turns on. I never see blue flames that would indicated the gas igniting.
Can you suggest what steps I should take next?
Old 01-13-13, 05:21 PM
hvactechfw's Avatar
Received 4 Upvotes on 4 Posts
I made you your OWN thread......... Check the diagnostic light on the control board.... What did you find?
Old 01-14-13, 11:27 AM
SeattlePioneer's Avatar
Received 1 Upvote on 1 Post
"a few seconds" is a vague comment. How many seconds does the ignitor have to heat up before shutting off?
Does the main burner gas switch on after the ignitor starts to heat up?
