Williams Gas Double-Sided Wall Heater
The pilot light is lit but when I turn the thermostat on, the pilot goes out and I have to turn down the thermostat to re-lite pilot light. I have changed the wire ends and had the sensor checked and the pilot mechanism checked all is fine. It came on after hitting the inner pipe going up to the furnace and it came on but it keeps going out and will not fire up what can I do to get it to stay lit and fire up when needed?
Sounds like you have a millivolt system. The most common cause for problems in this type of system is a dirty pilot. It may appear to be clean, but I would still blow some air into the portion where the flame comes out. You may also have a small hole in the side of the pilot burner, "primary air" opening. If you see this then blow air thru there.
