Oil Furnace
Old 01-16-13, 04:52 PM
L
Oil Furnace
Hi,My heat would not go on after I turned up the thermostat. I pushed the rest button and the oil furnace kicked on. It stayed on until my home heated. So I waited, then turned up the thermostat a couple of hours later,and the same result the furnace will not go on. Please help if you can.
Old 01-16-13, 06:41 PM
Received 3,880 Upvotes on 3,477 Posts
There can be a number of problems with your oil furnace.
A partially clogged nozzle.
A partially plugged oil filter.
A dirty Cad sensor. This is the sensor that "sees" the flame and shuts the unit down if the flame is missing or not correct.
An intermittent high voltage transformer.
Worn spark electrodes.
When was the last time you had the burner cleaned ?
What is the make and model of your unit.
Old 01-16-13, 08:55 PM
Grady's Avatar
Received 41 Upvotes on 39 Posts
I'll add another to PJ's list. Weak ignition transformer. This is a common problem with iron core transformers & once in a while with the electronic type.
Old 01-19-13, 05:00 AM
L
furnace will not reset.
Hi,my furnace will not reset. I reset it the other day and it worked fine. Now it will not reset. When I press the button nothing happens the light is blinking. I got an oil delivery and this happen. Please help if you can.
Old 01-19-13, 03:48 PM
Grady's Avatar
What is the make & model of the control on which the blinking light is installed? Do you have one or two copper lines from the fuel tank to the furnace?
