Thermostat RoberstShaw 9725i2 versus Lennox SignatureStat
My thermostat Lennox SignatureStat is acting up (display comes and goes). I was wondering if anyone knows if I could use the RobertShaw to replace the Lennox (same connections for wires/termination)?
I have an outdoor temp sensor and the furnace is a Lennox G61MPV (two stages variable speed).
Thanks.
Thanks.
The signature stat has had problems from day 1 in my experience. It would be best to move to a Honeywell, or Ecobee, or Emerson thermostat in my opinion. This will require more than just simply changing the thermostat though. I recommend a professional to do this.
Thanks for your reply. But what about the RobertShaw I mentionned? It looks identical to the SignatureStat, which I love, in spite of it flaws.
I've looked at the Lennox Comfortsense 7000, as well as the Honeywell, but I wasn't impressed with the touch screen.
I really like the SignatureStat. It recently developped vertical dark blue lines on the display that come and go, but apart from that, it has been reliable.
The RobertShaw I mentionned seems to be a copy of the SignatureStat, so I would go with that one if possible???
Thanks.
Thanks.
