the gas to pilot light shuts off after running a few cycles or about 8 hours
New Member
I have replaced the thermocoupler and evn adjusted the coupler but still runs only for a while instead of like it is suppose to any suggestions
It would be nice to know what kind of device we are talking about.
Is it natural gas or propane ?
Usually a make and model number can be a big help.
You have a standing pilot light that stays lit all the time, is that right?
If so, the most common reason that the pilot drops out is a dirty pilot burner and pilot orifice.
The pilot flame should look like a small blowtorch, with the flame engulfing the tip of the thermocouple. If the flame is yellow tipped or a "soft" flame that can be blown around like a candle flame, the pilot likely is the problem.
The pilot burner and pilot orifice should be cleaned in any case since it's a like cause of a problem, is ordinary maintenance that should be done once/year, and costs nothing to do other than some time.
Yes, don't replace the thermocouple unless the pilot doesn't stay lit right after releasing the knob/button. The orifice is most likely plugged.
Thermocouples are extremely reliable.
