Go Back  DoItYourself.com Community Forums > Heating, Cooling, Air Conditioning, Ventilation and T-Stat Controls > Gas and Oil Home Heating Furnaces
Reload this Page >
Furnace has strong, sub woofer like rumble, and electrode constantly sooted
Old 01-28-13, 10:12 PM
K
Hello, I've gotten my furnace running and not leaking a huge amount of oil underneath anymore.
I'm now trying to solve two issues with it.
The first one is that it quite often rumbles somewhat like a sub woofer when running and can be felt throughout the entire house while it runs (first 5 mins or so are strongest and rattles the heat ex changer).
the next issue is that the electrodes are constantly getting soot between them and causing a short preventing them from starting about once every 4-5 cycles.
The issues may be directly related, could it be perhaps running too air rich or lean? or have some other airflow restriction issue?
Old 01-29-13, 05:51 AM
N
Received 21 Upvotes on 18 Posts
Sounds like you may have an Air/fuel ratio issue.
Not knowing the history of your unit, when was the last time it was cleaned, filters and other consumables replaced?
Old 01-29-13, 11:20 AM
K
its . Bottom firing iron fireman vortex unit (post ww2)
Consumables are All new.
I'll try adjusting the air shutters a bit more.
Old 01-29-13, 09:24 PM
K
I ramped up the airflow and Its far less intense, I also vacuumed a huge amount of debris out of the duct going to the chimney, what is the likelihood of a restriction in the heat ex changer?
Old 01-30-13, 04:52 AM
N
Is there any reason you are running such an old system?
I'm assuming it's not a nice looking show piece (like my 1930's piston pump I still use).
It sounds like you are having issues with it. Might be time to concider replacing it and saving the trouble and fuel costs.
Old 01-30-13, 10:41 AM
K
Indeed, right now I am dirt poor however. Im hoping to get atleast one last year of service from it.
