Bryant 80 Short Cycle possible limit switch?
Old 01-31-13, 06:34 PM
R
I have a Bryant 80. My Thermostat is calling for heat the furnace turns on the induction fan goes for a minute or so and the burners ignite. About 4-6 minutes later the burner turns off, the fan is still going. About 6 minutes later the fan stops the induction fan starts and so on.
I have a humidistat hooked up to the control panel. When the burner turns off the humidistat power gets cut as well.
Hopefully that helps figure out the issue.
I have reading a little about limit switches but not sure what all that means.
Old 02-05-13, 08:01 PM
user 10's Avatar
Received 57 Upvotes on 50 Posts
Does the main blower ever come on during the heating cycle?
Does the blower work with the t-stat fan switch set to on? (or in a/c mode, if you have it. - shut off outdoor unit's breaker before trying it if it's below 60F outside)
What's the model number of the furnace?
Do you have a multi-meter and know how to use it?
