Go Back  DoItYourself.com Community Forums > Heating, Cooling, Air Conditioning, Ventilation and T-Stat Controls > Gas and Oil Home Heating Furnaces
Reload this Page >
Nordyne G6RA 80+ Furnace - red light flashes once, no heat, blower continuous
Old 02-10-13, 11:22 AM
D
No heat today - red light w/ 1 flash (= Limit Circuit Open or External Load on "W"). Thermo fan is on "Auto", Temp is "off" , but blower still runs.
I cut power at panel for 1 minute, turned breaker back on, and within 5-6 seconds the fan came back on again. Still no heat, still single flash.
And, oh, by the way, it's Sunday, of course
-Dennis
Old 02-10-13, 11:58 AM
Houston204's Avatar
Received 94 Upvotes on 87 Posts
What type of air filters do you use?
Is the air filter clean now?
Do you have a meter?
Looks like you have a vent safety switch and a roll-out on the limit circuit, they usually have manual reset buttons. We would also need to verify why it tripped.
Old 02-10-13, 12:24 PM
D
Huston204: I have a fairly inexpensive fliter - cleaned 10 days ago. I did have an issue once w/ a too-dirty filter (which I cleaned/replaced, and it solved the problem), but this seems to be a different issue. I did try to reset the vent safety switch - to no avail.
We do have a meter - it's a Sears 982361. Never really used it.
Old 02-10-13, 12:36 PM
D
UPDATE: We pushed the Roll-out switch, it reset, I turned power off then on (because the fan was still going), and now it is working again.
What would cause the roll-out switch to trip??
Old 02-10-13, 12:49 PM
D
UPDATE #2: It tripped again, and I now have the blinking red light again. It did bring it up to temp, however, before it shut off. Fan is still blowing (but it's not turned on at the stat).
Old 02-10-13, 12:57 PM
Houston204's Avatar
The most likely cause for a roll out switch to trip is a crack, hole or restriction in the heat exchanger.
Sounds like its time to call a pro.
