Carrier gas pack - Model 584bnw048080aabg
Old 02-10-13, 11:30 AM
F
Hello,
i am trying to figure out how to determine if the heat exchange unit is bad on my heat pump. The symptoms is that it now only blows outside temp air. It used to once we initially discovered the problem, would blow warm air for about 2-3 min, then it would blow outside air temp.
Does anyone have any advice, the unit is the original unit installed in 1991. I am pretty handy and have the tenacity to dive in, any idea where I can find a users manual or schematic for how I can disassemble.
Thx
frog
Old 02-10-13, 12:34 PM
Houston204's Avatar
Received 94 Upvotes on 87 Posts
http://www.docs.hvacpartners.com/idc...584b.18.2d.pdf
Does the compressor continue to run when it stops heating?
Old 02-10-13, 05:35 PM
F
Carrier
Not sure, I actually tried it today and watched it, it never ignited. No flames, nothing. The fan kicked on like normal.
Thx
Old 02-10-13, 07:42 PM
Houston204's Avatar
Did the induced draft motor start?
21 years is a very long life for a gas package unit. I'm surprised that the heat exchanger has lasted this long. I would expect a roll-out switch lockout. This unit appears to have a non resettable roll-out switch.
This is not a heat pump.
Old 02-13-13, 02:12 PM
F
Thanks for getting back to me, if the little motor on the bottom with the fan blades (see attached picture) is the motor you are speaking of, then yes, it does run.
I did not see the IDM on the schematic.
Old 02-13-13, 08:09 PM
Houston204's Avatar
Do you feel air moving out of the induced draft motor grill on the side of the unit?
Do you have a meter?
Old 02-15-13, 05:00 PM
F
Hello Houston, I want to first thank you for spending time with me, I do appreciate it.
1. Yes, there is air blowing out of the side vents
2. And yes I have a digital volt meter
One note, I was looking at the unit while it was running and it appears that there is a constant spark right below the heat exchange tubes, not sure if that is normal or not, but thought I would tell you.
thanks
Gary
Last edited by hvactechfw; 02-15-13 at 05:15 PM. Reason: The idea of the forum is to keep the info here so that others can benefit too
Old 02-15-13, 05:43 PM
Houston204's Avatar
Sounds like you need to clean the pilot orifice.
Usually need a 7/16" or 3/8" open end wrench to unscrew the pilot tubing from the pilot assembly to gain access to the pilot orifice.
Old 02-16-13, 09:46 AM
F
ok,once I do that, do you still think the heat exchanger is cracked? As I mentioned, the first symptoms when we first noticed a problem (1 yr ago), was that it would blow warm air like normal than after 5 min or so it would just blow outside temp air.
Old 02-16-13, 10:54 AM
Houston204's Avatar
You can clean the pilot orifice and flame sensor, restart it and observed the sequence of operation.
The 1/4" tube from the gas valve should lead you to the pilot orifice.
Your roll-out switch is not locking out or it wouldn't reset. This still leaves the limit switch. Is the evaporator coil clean?
It is a 1991 gas heating unit. Having it serviced or replaced isn't unthinkable.
A carbon monoxide detector should be present in any house with a gas heating unit.
