Furnace and water heater vents
Old 02-15-13, 07:29 AM
B
Looking at a houw with oil heat - and what I found strange was that the water heater was also oil fired. Apparently the furnace requires a 7" duct up the chimney - and the water heater also requires a 7" duct up the chimney. I am told these should be separate - but the water heater vent goes into the furnace vent - which then goes up the chimney. Is this a problem?
Old 02-15-13, 05:51 PM
hvactechfw's Avatar
Received 4 Upvotes on 4 Posts
NO, they can be common vented. As long as both have a draft regulator.
Old 02-15-13, 06:26 PM
B
I don;t recall a damper on the water heater (but I could be wrong). I know there was one on the furnace - because it was broken
