Amana Air Command 80 SSE Won't Come BACK On...
Old 02-18-13, 04:55 PM
T
Unhappy Amana Air Command 80 SSE Won't Come BACK On...
I have an Amana Air Command 80 SSE. My problem is that it's not coming back on after a cycle of heating unless I manually pop open the bottom of the two covers. In fact, I don't even have to take it off completely -- I just have to pop out the corner a bit, push it back in and that starts the furnace. It runs perfectly then. But for whatever reason, after the cycle is complete, it won't come back on unless I manually open and shut it again. Any thoughts?
Old 02-18-13, 07:51 PM
hvactechfw's Avatar
Received 4 Upvotes on 4 Posts
check the diagnostic code that is viewable through the window in the blower door. You are effective cycling the power through the door switch opening and thus resetting the control board.
