Payne Gas Furnace Blower won't stop
Old 02-20-13, 01:37 PM
ModelPG8MAA year built 2006
Blower constantly runs. Will not fire up. LED code starts at 33 then gies ti 13.
Please help!
Old 02-20-13, 03:43 PM
SeattlePioneer's Avatar
Received 1 Upvote on 1 Post
Carrier diagnostic codes are described at:
http://www.xpedio.carrier.com/idc/gr.../58mvp-6sm.pdf
The diagnostic codes you have are signaling that the furnace is overheating and the burners are shutting off on the overtemperature limit switch.
The usual reason for the furnace to overheat is that something is preventing air from circulating past the heat exchanger to strip away all the heat being produced by the burners.
Common reasons for this include a plugged furnace filter, blocked return air vents, or warm air vents that are closed.
Start by checking those and report back what you find. There are other things to check if none of those are the problem.
