GOODMAN gas 45,000btu furnace,
Old 02-25-13, 03:20 PM
K
GE gas Furnace, 36,000btu
Model#: GMH80453ANAA
Serial #: 0607233658
The ignitor turns on/glows, gas is hitting it and igniting for about 3 seconds, A blower motor kicks on and then the flame shuts off, the blower moter stays on and the flame reignites and it just repeats.
Old 02-25-13, 05:00 PM
Received 3,982 Upvotes on 3,574 Posts
Your unit uses a flame sensor rod and it sounds like it needs to be cleaned. It's held in place with one screw. Remove the one screw.....disconnect the wire. Clean the rod with steel wool or even better is a Scotchbrite pad.
In the link below it's part # 11 in the "burner box" section all the way at the bottom.
http://johnstonesupply9.com/TechDocs...IR%20PARTS.pdf
Old 02-25-13, 07:03 PM
K
Thank you, that's what some buddies at work were recommending. I'll do that first thing when I get home in the morning.
Old 02-25-13, 07:20 PM
Let us know how you make out.
Old 02-26-13, 05:01 AM
K
That was the problem, furnace is now working. Thanks again!
Old 02-26-13, 08:27 AM
That's great news......
