Induced draft motor cycleson a nd off
Old 02-27-13, 11:46 AM
Induced draft motor cycles on and off
My Goodman model GMP 125-4 gas furnace has an induced draft motor that has recently started short cycleing, intermitantly. Sometimes it will run for a few seconds and shut off, sometimes for only a second. Sometimes it will funtion as it always has, start and run for 20-30 seconds, then the burner will come on and run a normal cycle. When the thermostat calls for heat is the only time it comes on, but sometimes it will shut off without anything else happening. Sometimes it turns on and off a number of times before it will run a normal burn cycle. Whenever 110 volts is applied to the motor it runs, so I know something else is opening, causeing it to shut off.
Old 02-27-13, 06:36 PM
Received 3,884 Upvotes on 3,481 Posts
Welcome to the forums.
There is a control board in your furnace that pretty much runs the show. Your draft inducer (power venter) is connected to common neutral and IND terminal. There would be 120 vac on those terminals when the inducer should be running.
There is a PVR (power vent relay) on that board. When thermostat calls for heat that relay would engage and start the inducer blower. If the thermostat had an issue..... you would hear that relay chattering in time with the inducer starting and stopping.
Based on not hearing that relay chattering ...... the relay contacts are burned/intermittent and the control board needs to be replaced.
In the link your schematic is on page 67 of the PDF.
http://www.hvacpartsshop.com/Gmph075-4%20Series.Pdf
Old 03-03-13, 08:26 AM
Thanks
That seems logical. I thought it had something to do with the control board. After reading your post I waited for the problem to surface again and when it did I explored further. I found that by tapping on a black plastic cube attached to the control board I could effect the power venter turning on and off. Thanks for the advice.
Old 03-03-13, 09:02 AM
That black plastic cube would most likely be a relay.
It's good you were able to reproduce the problem. Intermittents can be pretty difficult to isolate.
Old 03-03-13, 09:54 AM
Thanks again
Guess I'll be trying to get a control board...that couldn't cost to much, ha ha
Old 03-08-13, 05:30 AM
Thanks
$110 for new board. Fairly easy to install. Been working fine for a few days now.
