Amana Gas Furnace leaking water
Old 03-27-13, 08:10 AM
8
Amana model #21230C175B160167
I noticed water on the floor by the furnace and found water coming from the lower edge of the air chamber(name?) that holds the blower fan. this furnace has a pump that pushes condensation up to the ceiling and over to a laundry tub. the pump housing has some water in it, but not full or over flowing.
Must be some hose blocked, I guess, but not that I could find.
Is there a common problem I can look for?
thanks!
Old 03-27-13, 03:41 PM
hvactechfw's Avatar
Received 4 Upvotes on 4 Posts
no common problem... you need to trace the source of the water.
Old 03-27-13, 04:10 PM
Received 4,114 Upvotes on 3,695 Posts
Do you have a humidifier. Maybe it's overfilling.
Old 03-27-13, 10:25 PM
8
no humidifier. I guess I am left with taking things apart. i was so hoping to just put some compressed air through one of the drain hoses for an easy fix!
thanks for your help!
