Wi-Fi thermostat 'C' wire questions
Old 04-03-13, 09:57 AM
B
Hi Folks,
I'd like to buy a Honeywell Wi-Fi thermostat, but I want to make sure I understand how it install it first.
The 'C' wire from the furnace is Common, or Ground.
But my (c. 1987) Utica Starfire II oil furnace with tankless h2o has a (Honeywell) board with no post marked C or Ground, and the power wire bundle to it has only white & black. That means the chassis is ground, right? And I can connect the thermostat to a wire terminating into the chassis? What gauge wire should I run? (The bundle to the thermostat only has hot & neutral wires, no spares. The wife won't let me buy a stand-alone transformer for the tstat 'cause she doesn't want a wire running down the wall.)
Thx,
-brawk
Old 04-04-13, 12:19 PM
G
Received 2 Upvotes on 2 Posts
I'm not sure what you are referring to when you say chassis. A common wire would run from the furnace, attached to a ground potential part such as the frame of the furnace. 18 gauge wire is fine for this application.
