Miller furnace won't run
Old 04-18-13, 04:44 PM
L
This seems to be the spring to replace everything at my cottage.
I have a 20yo miller lp furnace. I had the tank filled this week and the pilot went out. When I showed up today and try to restart the furnace it won't run. The pilot is lit and the blower work because I can manually start that. I can't hear the small motor that runs it light. That motor won't run when I turn it on. I already double checked the thermostat. Any ideas? Is there a reset maybe?
Old 04-18-13, 05:42 PM
SeattlePioneer's Avatar
Received 1 Upvote on 1 Post
Take the cover off the burner compartment of the furnace.
Describe in detail and in order the sequence of events that occurs when you turn up the thermostat.
You have a standing pilot light that remains on all the time --- is that right?
Old 04-19-13, 12:15 PM
L
Yeah standees pilot. When I term the thermostat up I hear a slight buzz and that's it.
Usually you a motor running and furnace ignites then a minute later the fan will kick on.
Now when I turn the thermostat up I don't here the motor running.
Old 04-20-13, 02:06 PM
A motor for what?
Most furnaces that have standing pilots only have a motor to circulate air around the house. Is that the motor you are talking about, or another?
Do you have a multimeter and understand how to use it?
You want to measure the AC voltage between the furnace sheet metal ground and the W terminal on the furnace. You should see 24 VAC appear at that terminal when the thermostat is turned up.
Check to see if you have AC voltage turned on to the furnace.
Old 04-21-13, 07:41 PM
Grady's Avatar
Received 41 Upvotes on 39 Posts
Probably a silly question but, when you lit the pilot did you turn the gas valve from the pilot setting to "on"?
