blower runs constantly
Old 04-21-13, 11:58 AM
R
I have an elect aire furnace. The blower runs constantly but there is no heat. The code flashing says limit circuit open. Any suggestions to the problem?
Old 04-21-13, 12:11 PM
G
Received 28 Upvotes on 27 Posts
Pull out the wiring schematic. There should be a bonnet thermostat that is probably stuck on hi temp ('stat contacts open) or an open in the circuit. That would shut off the heat circuit and keep the blower running. Troubleshoot with a multimeter.
Old 04-21-13, 01:23 PM
hvactechfw's Avatar
Received 4 Upvotes on 4 Posts
If it is an ELECTRIC furnace then BEWARE!!!!!! HIGH VOLTAGE EXISTS in the cabinet.
