Nordyne intertherm not heating.
Old 04-21-13, 01:58 PM
Talking Nordyne intertherm not heating.
I have a '99 Intertherm model M1GH090ABW standing pilot with induced draft. LP gas fired. The flue blower does not kick on when calling for heat. I hear the "relay" click, but no blower. The pressure switch is ok. I can get the burners to ignite by gently blowing into the pressure hose. The furnace runs when a/c is called for. The flue blower turns easily and does not seem locked up. Anyone with some help?
Old 04-21-13, 02:17 PM
hvactechfw's Avatar
Received 2 Votes on 2 Posts
Verify voltage to the motor............................
Old 04-21-13, 02:36 PM
Notta....nothing.....no voltage to motor
Old 04-21-13, 02:47 PM
hvactechfw's Avatar
Where do the motor wires come from? That is likely the culprit.
Old 04-21-13, 03:22 PM
I have given incorrect information. After checking the relay/coil I have 120 volts coming from the relay/coil terminal to the flue blower. After rechecking the wiring to the blower I have 120 volts going to the flue blower. Flue blower bad?
Old 04-21-13, 03:47 PM
hvactechfw's Avatar
sounds like the motor is bad, yes.
Old 04-21-13, 04:04 PM
Thanks for your help Kevin
