80MGF4/5-140A-12 Induced Draft Blower Part#
Old 04-22-13, 03:46 PM
haloguy628's Avatar
The Induced Draft Blower on my 80MGF4/5-140A-12 was replaced. It works fine but when I looked at the part numbers the old and the new P/N are not the same. Just want to make sure that the new part is the correct one as there is difference in Amps rating.
The old P/N: 60L2401 0.8A
The new P/N: 88J3901 0.7A
Appreciate your help.
Old 04-22-13, 04:31 PM
Received 3,980 Upvotes on 3,572 Posts
It is very common for a part to be superseded by a new or different part number.
If the new inducer is working correctly then you should have no issues.
The slight difference in current draw is ok,
Old 04-25-13, 04:26 PM
haloguy628's Avatar
Thank you for your reply.
I actually found parts list for all 80MGF furnaces, and it has the 88J3901 listed as replacement part in the 100A, 120A and 140A series.
