Oil Burner Smell
Old 04-23-13, 07:55 AM
B
Oil Burner Smell
I heat my home in the winter with wood 95% of the season and only use about one and a half tanks (275gal) of fuel oil a year.
I had let my oil tank run pretty low to the point I was almost out. To save some fuel I shut off the furnace on Friday night and called for delivery on Saturday morning.
Shortly after I turned the furnace back on, on my basement was filled with smoke. The burner was firing and I was getting hot water.
I had thought my issue had to do with the low tank level (water/sludge?) and shutting down the system.
I changed the nozzle, and brushed and vacuumed the boiler. The nozzle seemed to be a bit oily when I removed it.
Got a delivery of oil and shut down the furnace for 20mins when the truck came.
No problems Sunday or Monday but this morning, Tuesday, I have trace amounts of smoke and a fuel smell.
Would it be a oil drip problem that accumulates at night (low thermostat - furnace NOT off) and then 'pops' when the burner fires or something else?
Old 04-23-13, 07:10 PM
Grady's Avatar
Received 41 Upvotes on 39 Posts
I'd start by changing the filter & pump screen then flushing a saftey cycles worth of oil thru the nozzle assembly (less nozzle) & into a container before replacing the nozzle. You could very well have a crapped up fuel system.
