Furnace blower not working need advice!
Old 05-26-13, 02:12 PM
C
My Winchester heater is not working. When turned on works right up to when the blower is to come on. The blower twitches but does not spin. If I reach in and spin the wheel it will then come on and work. I have replaced the cap and motor and is still doing the same thing. I get error codes mainly flame sensor lockout but sometimes others. I have cleaned the flame sensor without help. Is it the board? What should I try next? Thanks for taking you time to add your opinions... I do appreciate it
Old 05-26-13, 05:27 PM
Received 4,049 Upvotes on 3,632 Posts
Normally you would measure the voltage going to the blower before replacing the motor.
Is this one of those hanging garage heaters ?
Can you leave a model number.
You need to tell us what is happening in the order it happens.
Old 05-27-13, 07:43 AM
hvactechfw's Avatar
Received 4 Upvotes on 4 Posts
As stated we need more info on your unit. DO you have a volt meter and know how to use it?
