Can I use hevy duty aluminum foil for furnace vent?
Old 05-30-13, 08:57 AM
L
I have 80,000 BTU gas furnace, the vent pipe up to the attic and out above the roof is broken the at the 45-degree angle connection, the separation is about 1/2" and it's hard to replace that 45-degree pipe due to space limitation.
Can I use either heavy duty aluminum foil or even cut off the aluminum cooking pan to wrap around this area, then tape it with aluminum duct tape?
Thanks,
Old 05-30-13, 09:17 AM
ray2047's Avatar
No, the danger from fumes is too great to jerry-rig it. You need to do a proper replacement.
Old 05-30-13, 05:14 PM
G
Received 28 Upvotes on 27 Posts
No, you can't. Call a professional before you kill yourself and others.
Old 05-30-13, 06:28 PM
hvactechfw's Avatar
Received 4 Upvotes on 4 Posts
NO! Call a professional and have it done right! No amount of money is worth risking your or your family's life.
