XR-90 TRANE Furnace doesn't start up, No Red LED
Old 06-01-13, 02:28 PM
R
Question XR-90 TRANE Furnace doesn't start up, No Red LED
Hi, I have a XR-90 Trane furnace, installed in 2004. It was working fine both heating and cooling. But as of today, it doesn't turn on. Red LED doesn't come on as before, but if I press the on/off safety switch on the access panel 2 times quickly and the LED lights up with some click sound. However the LED has very low brightness. And does not start up anything. No fan running in "auto" or "on" mode. Only hear a humming noise from the transformer.
What could have gone wrong? Please help to determine the problem.
I appreciate your help.
Thank you,
Rishi
Old 06-01-13, 03:08 PM
Received 4,050 Upvotes on 3,633 Posts
Welcome to the forums.
Is there a protection fuse on the board...... if so..... have you checked it ?
Do you have a volt/ohmmeter ? It may be needed here.
Old 06-01-13, 03:27 PM
R
Thank you.
I checked the fuse, it is ok.
I have a multimeter.
Old 06-02-13, 05:18 AM
hvactechfw's Avatar
Received 4 Upvotes on 4 Posts
Check for 24VAC between R and C at the control board in the furnace. Remember to push the door switch in.
