Gas Furnace not working
Old 06-02-13, 08:46 PM
I helped a buddy put in a Airease G1N80BT in "09" and last week it quit running. The problem we are having is when you put power to it all we get is a humming sound and that's it. The blower does not run and we get no read out on the thermostat. We did test the capacitor for the blower when it was running and it was a little weak at 5.5 instead of 7.5. I replaced this and still having problem. Please help us. Thank you
Old 06-03-13, 06:03 PM
hvactechfw's Avatar
Received 4 Upvotes on 4 Posts
check for 24VAC between R and C on the control board of the furnace. Don't forget to push the door switch in when checking voltage. There may be a fuse on the control board. Check to see if it is blown.
