furnace filter help
furnace filter help
I have a tempstar furnace that I need help determining what the proper filter for it is. model# NDGE105NF02/867.768081 and serial# L884737826. This furnace was in my home when I bought it, but when I went to replace filters.....there was none. Thanks in advance for your help!
No return grill filter either?
No Pro...but most units just take a 1" filter of the correct size. Did you at least find where the filter is supposed to be if it's installed at the unit?
Yes I know where it is located. it's a forced air unit and the filters go just above the blower fan....I was just trying to see if anyone knew what size filter it takes without trying to squeeze a tape measure in to try and measure it is all.
Ahhh Ok. Sorry we couldn't help. If Kevin couldn't find a reference manual...probably cause it's so old.
