Advice please on heater problems
Old 06-19-13, 10:43 AM
C
I have a heater I am trying to fix and need some advice. Its a gas home heater with the name Winchester on it and model #G8T10012UHB11A. When the heater comes on it will run normally until it is time for the blower to come on. It will twitch but not start. If I reach in and give it a spin at that point it will start up and spin. The board gives errors at different times but mainly the error is a lockout error. I replaced the capacitor and the motor without change. Is it the board? I haven't checked voltage at all... probably should have done that before replacing the motor. Any thoughts would be appreciated
Old 06-19-13, 06:19 PM
Grady's Avatar
Received 41 Upvotes on 39 Posts
Sounds like you have a bad fan motor.
Old 06-19-13, 07:39 PM
lawrosa's Avatar
Super Moderator
Received 85 Upvotes on 77 Posts
Grady you read the post????? See below statement....
Old 06-20-13, 06:03 PM
Grady's Avatar
Whoops. I read it as "the capacitor ON the motor".
What Chilrais describes is classic weak capacitor but with it & the motor being new, the chances of getting a bad motor are greater than getting a weak cap. Neither is unheard of.
