intermittent blower fan
Old 06-26-13, 06:13 AM
W
I have a York furnace. Recently the fan (when either the heat, air conditioning or just the fan is on) will run for a period, a thumping sound occurs and the fan shuts off temporarily, approximately 5 sec. This could occur once within a run or 2-3 times within a run. The fan then continues to work fine until the cycle ends. The amber light on the front of the furnace continues to flash normally indicating the furnace operation is fine.
Old 06-27-13, 01:35 AM
Received 3,892 Upvotes on 3,489 Posts
Welcome to the forums.
The orange light on the front is basically indicating the burner operation is normal. It doesn't really monitor the motor for actual fan motor issues.
I can not think of why the motor would start thumping unless it's a belt driven model and it's time for a belt. Have you taken off the blower door and made a visual inspection ?
Old 06-27-13, 04:28 PM
hvactechfw's Avatar
Received 4 Upvotes on 4 Posts
Is it a Variable Speed blower?.............................
Old 06-28-13, 08:33 PM
W
yes blower is a variable speed
Old 06-28-13, 08:38 PM
W
yes we checked out the area where the fan resides, vacuumed the fan, not sure if it is belt driven. I will need to check this out. I should have said the furnace makes a groaning(not thumping) noise prior to the blower shutting off.
