A power outlet with switch from the power feed/control feed to TRANE XE 60
Old 07-19-13, 11:15 AM
B
Hello,
We live in NJ and we bought this house 3 years back. We have not replaced the furnace yet and I don't think it was ever replaced so approx. age is about 21 years.
There had been a switch (see picture) and an outlet underneath which in turn goes to the control/circuit of the furnace.
If the switch is off, the furnace/blower would not start.
Any idea what is the purpose of the power outlet might be ?
Thank you.
--Pratik Patel
Old 07-19-13, 11:26 AM
Received 3,983 Upvotes on 3,575 Posts
Welcome to the forums.
Obviously the switch is a service switch for the furnace. The receptacle could be for a serviceman receptacle or possibly for a humidifier.
F
It is for a service person to plug in a work light, other power tools or a combustion analyzer. If there is another receptacle within 25 feet of the furnace you do not need the one on the furnace itself.
Old 07-19-13, 11:31 AM
B
Thank you Furd and PJmax
There are many receptacle in less than 10 feet (atleast 6). There is also humidifier on the other side of the furnace (not in use).
Thank you again.
Old 07-19-13, 12:01 PM
F
When I had a new furnace installed the company insisted on installing a receptacle alongside the service switch. When I pointed out the receptacle not three feet from the furnace they installer merely shrugged and said it was company policy. After they came back a month later and installed the correct furnace I took off the unneeded receptacle.
Old 07-19-13, 08:49 PM
Houston204's Avatar
Received 94 Upvotes on 87 Posts
I often install them at the furnace when installing 120VAC UV lamps.
