Hello, I need to put in 2 Floor Registers 8" x 10"
Old 08-21-13, 10:53 AM
T
And my simple question is.. what material isn't effected by water.. because these go in a bathroom and basically right below a sink?
I'd like to use steel.. but doesn't that rust?
Amazon.com: Floor Register, 8" x 10": Home Improvement
They also make e'm in cast iron? and brass/brush knickel?
Honeycomb Cast Iron Floor Register Louvers 8" X 10" | eBay
Oversize Honeycomb Brass Floor Register W Damper 8" X 10" Brushed Nickel | eBay
Can anyone help with a material that is water resistant or am I just screwed on that?
Old 08-21-13, 12:06 PM
airman.1994's Avatar
Received 8 Upvotes on 8 Posts
Just get what you like! In the end everything will rust tarnish or spot because of moisture and chemicals.
Old 08-21-13, 05:00 PM
T
Hmm.. plastic does though right.. I wonder if I could get a plastic laminate or something?
