Trane furnace pilot light (Model txc018a4hpa0)
Old 08-25-13, 08:16 AM
H
Turned it off to drop a flea bomb. Do I restart it like a bunsen burner or is there an easier way?
Old 08-25-13, 09:44 AM
G
Received 2 Upvotes on 2 Posts
Kind of like a Bunsen burner. Turn the gas valve to pilot and push down or if there is a separate start button - push it down while lighting the pilot with a match. Continue to hold the button down for at least 30 seconds and then release. If the pilot stays on, turn the gas valve to the normal position and you should be ready for cool weather.
Old 08-25-13, 09:56 AM
H
Dug in and found the switch in question. All lit now, thanks.
