Forced air vs boiler replacement considerations
Old 10-02-13, 07:05 PM
G
Do people with forced air systems have the same issues to consider when replacing a furnace as those with boilers? By this I mean the need for a heat loss calculation, outdoor reset, size of ductwork, computerized controls, different heat exchanger materials, condensate disposal, zones. As always, I am curious. Thanks.
Old 10-02-13, 07:47 PM
NJT's Avatar
NJT
NJT is offline
Received 8 Upvotes on 6 Posts
Hi Gundi, I'm going to move your post over to the 'Furnace' forum from the 'Boiler' forum...
I imagine that all the principles are more or less the same, one would have to know how many BTUs are needed... and that is then related to the size of the ductwork to each room... I don't really know enough about hot air systems to give accurate comments though, but the guys on the 'hot air' forum should...
Old 10-03-13, 07:45 PM
Grady's Avatar
Received 41 Upvotes on 39 Posts
For all practical purposes, yes. In fact, scorched air systems are more critical. Undersizing ductwork for the furnace will lead to heat exchanger failure.
