275 gl oil tank question
Old 10-03-13, 09:42 AM
Bernard_01's Avatar
Old fisherman here in New Hampshire,
I am installing a new horizontal oil tank from the Depot. The accessory kit is sold separately. It will draw from the top. At the bottom, do I still need some type of valve to drain condensation ? the top will have the fill pipe...the "whistle"....the vent pipe & gauge or should those be separate from each other?
thanks.
Bob
Old 10-03-13, 07:39 PM
Grady's Avatar
Yes there should be a drain valve on the tank bottom. Be sure to install a cap or plug on/in the valve to prevent accidental opening.
If the tank has four tappings on the top, use separate tappings for the fill, vent (whistle), gauge, & supply line. If there are only three, you will have to use a combination vent (with whistle) & gauge. Be sure to install a flared shut off valve as close to the tank as possible in the burner supply line.
Old 10-04-13, 06:49 AM
Bernard_01's Avatar
ty
thank you mr. grady.......you always give me the correct anwers !
Old 10-04-13, 05:17 PM
Grady's Avatar
You're most welcome. I try my best to give folks the information they need.
