Furnace won't turn on.
I have a Day & Night gas furnace which will not turn on. It's like there is no power at all. I had the same problem a few years ago and the service man who came out said it was a switch or relay that had to be reset but he didn't show me where it was. I have cycled the circuit breaker off and on. I took the covers off the furnace and the only switch I can find pops out when I remove the cover. I assume its a safety interlock. When that switch is pushed in a tiny red light starts to blink behind a plastic opening in the cover. The furnace is in the attic and over ten years old.
Check your low voltage fuse to see if it has blown. If it has blown you can replace it to see if it blows again. If so, you will need to locate the short in the low voltage control wiring. The model number of the unit is normally pasted on the inside of one of the access panels. Having the model number would greatly help to assist you better. Turn off power to the furnace before touching any wiring or the fuse.
http://www.xpedio.carrier.com/idc/gr.../58mvp-6sm.pdf
See page 19-20
There is an automobile style fuse on the circuit board that is probably open, usually 3 amp. Check that first.
If the fuse is open, look for a short to ground on the thermostat wire. Rather often, the thermostat wire gets cut on sheet metal ductwork, which will cause a short and the fuse to blow.
See page 19-20
