pilot blows out.
Old 10-19-13, 08:34 AM
T
pilot blows out.
i light the pilot, turn the heat on and it ignites then after a few seconds it quits and goes out. as you can see i'm not very technical or savvy. what could it be?
Old 10-19-13, 08:54 AM
Houston204's Avatar
Received 95 Upvotes on 88 Posts
Do you have a yellow tipped flame or a blue tipped flame on your pilot light?
You may need to clean your pilot orifice.
The flame on the left requires cleaning.
I usually use a combo 3/8 and 7/16 open end wrench to get to the orifice and a bristle from a wire brush to clean out the blockage.
It cold also be a crack in the heat exchanger blowing out your pilot. How long has it been since this furnace was professionally inspected?
Old 10-19-13, 09:12 AM
T
i dont know how long it has been. the pilot light looks like the one on the left with the yellow tip.
Old 10-19-13, 09:39 AM
Houston204's Avatar
Shut off the gas and power to your furnace, disconnect the pilot tube from the base of the pilot and , if your lucky the pilot orifice will fall out. You may need to tap the pilot assembly for the orifice to fall out.
Clean out the orifice with a stick pin or a bristle from a wire brush.
If the problem persists, having the furnace professionally inspected would be the safest option.
