A/C, Fan , Gas Furance not turning on. Help Plz
Old 10-19-13, 12:46 PM
R
Question A/C, Fan , Gas Furance not turning on. Help Plz
My AC, Fan, and Furance won't turn on.
Things I have replaced are
Control Board with exact same model
Safety switch for door
Transformer for unit
Things I have checked
I have 120v into transformer and 24v coming out
No lights on control board
I tried jumping wires at thermostat R to G, R to Y, R to W nothing happens
3 amp fuse on control board isn't blown
Breaker on the outside is not tripped(I turned off and on to reset)
Please help I don't know where to go from here
Old 10-19-13, 12:51 PM
Received 4,115 Upvotes on 3,695 Posts
Welcome to the forums.
On the board should be 24vac input. Did you check for power there ?
If it's at the transformer...... it should be at the board.
Old 10-19-13, 12:54 PM
R
How do I check for power at the board?
Old 10-19-13, 12:58 PM
Houston204's Avatar
Received 95 Upvotes on 88 Posts
Measure for 24VAC between R and C.
Post the make and model number of the furnace so we can see what we are working on.
Old 10-19-13, 01:07 PM
R
Also thank you for welcoming me.
Yes I have 24vac at board.
its a GMP100-3 Rev A
Control board is Goodman B18099-13 1012-933A
